Buzzing noise !!! ????
    Has any one has this problem...
    it could be a very noisey fan but
    It seems every time i'm in top gear at about 6000rpm after a few minutes i get this really annoying buzzing noise.. is this anything to do with the speedo light (does it have a buzzer aswell)
    only thing i can compare it to is a fuel pump noise..
    theres no power loss at all..
    I thought it could be my carb making the noise.. i've just (yesterday) fitted my fuel exhaust and didnt re-jet y carb..
    anyone else had this..
    not sure if it happened beofre i put the exhaust on because i stripped it as soon as i got it !
    Football is called football.. not soccer !!!
    Your american football.. you use your hands 90% of the time !!!
    I take it you have a JDM Bros?No idea if there is a buzzer along with a speedo light on it.
    For a buzzing sound,I'd look to the chain as the first culprit.
      did ya take ya center stand off? or fit a support bracket? ops:
        i took the stand off... it sounds like its coming from under the tank..
