Roll on the throttle and acceleration is a bit soft until 4500 rpm when the bike takes off like a rocket to 8000 rpm.The same in all gears...The engine is smooth, no stumbling or misfiring, no surging ,just down on power until 4500...Applying the choke slightly makes no difference .Uni filters, vacuum chamber vents clear ,smooth consistent idle, starts quick hot or cold..Spark plugs show no signs of an over rich or lean mixture..Maybe the slides are slow to rise up?
More carb. sillness
read and study the tuning instructions furnished with factory pro and k&n/dynojet carb kits, both available online."It's only getting worse."
7CDA6DA2-23AB-46BB-86B8-FB220DCAD323.jpeg I stopped dicking around and bought a new Factory Pro 3.0 kit from JHord.....#42 pilots, clip in needle middle notch, 158-153 mains,floats at 9.2mm.Uni filters, Cheap Ebay 1-3/4 core muffler. Checked the carb synch again with an air flow meter, best idle with screws 3-1/2 turns out.....the engine starts instantly cold with the choke needed for a minute or two...Good power off idle , no surging or flat spots and pulls cleanly to 8000 rpm...I am satisfied...Last edited by Hillbilly Bike; 09-26-2021, 09:05 AM.
- Likes 5
you might want to try #45 idle jets cuz with mixture screws out that far they loose spring tension and could fall out."It's only getting worse."
- I had that happen once... A dab of RTV sealer will keep them in place and will easily break free if they need an adjustment. The low speed response seems excellent and I really don't want to mess with it again..My usual riding friend is a Euro bike snob, lol ...He rode the NT and actually admitted it's a nice backroad machine with a responsive engine.
