Any recommendations for cleaning/cleaning chemicals a crusty bottom of gas cap and petcock? I have an ultrasonic cleaner and thinking i might try some evaporust(will have to look at content to see if its harmful to heat). Petcocks are made of some sort of s**t metal so idk what could harm it. Little worried about all the plastic bits too.
Rusty Gas cap/Parts Cleaning
Caustic soda works well with aluminium parts but should be used carefully as it will eventually dissolve them. I wouldn’t use caustic on the petcock as it may be made of a zinc alloy and that very readily dissolves. I’d use wire wool by hand or one of the little scotchbrite type buffing mops with a Dremel. I’ve also found that stainless steel pan scourers work very well for cleaning all sorts of manky metal parts, without being too harsh.
The petcock can be rebuilt, but requires drilling out the rivets and tapping for screws.
It may be that the parts of the fuel cap are also zinc alloy too.
Don't use Evaporust on the Gas Cap (or anything aluminum). Buddy ruined his using it temporarily while the tank was upside down to clean up the top. Ate the aluminum and fucked up the venting. We watch his gas cap bubble and spit at stops if you flip open the key cover. He can no longer use a tank bag.
Originally Posted by Captain 80s View PostDon't use Evaporust on the Gas Cap (or anything aluminum). Buddy ruined his using it temporarily while the tank was upside down to clean up the top. Ate the aluminum and fucked up the venting. We watch his gas cap bubble and spit at stops if you flip open the key cover. He can no longer use a tank bag.
