I picked up a 1988 hawk with 15 K. I cleaned the gas tank and clean the carbs, put on a new rear tire. It has not been on the road since 2010 and was low on antifreeze. I topped up the system probably didn’t burp it properly and after 30 miles of riding it was gurgling from the overfill tank. I topped it up again and took very little so I burped a couple times and I think I got all the air out. The thermostat fan are coming on just a bit over half way. I couldn’t get the idle to come down from 1400 rpm so I fiddled with the clamps and rubbers a bit and going to fit better. My idle is now 1100rmp I had to take the spacer on the lower clamp to get the lower clamp to go tight. I went for a 10 mile ride and it seems to be better but I’m gonna go for a longer ride today.
I would like to order intake rubbers and maybe a full gasket set as I plan to adjust the valves this winter it might have to deal with a head gasket if I can’t get the cooling issue straightened out. Where is the best place to buy intake rubbers and Gaskets at? What else should I consider ordering? Can you still source parts from Honda? I plan to change the brake fluid.
thanks
thanks
