Rubber tank bushings- needed or not?
    My bike doesn't have any of the rubber bushings that go between the frame and tank. Are they needed?
    na my bike never had them
    tank moves around a little bit more but its not going to hurt anything
      Yep, If you don't mind the tank moving. They are rather inexpensive though...
        Tannk Rubbers
        Don't need them absolutely perhaps. But if you use a tank bag, the weight may push it down to where the tank contacts the frame rail and makes a noise, (from experience) and or rubs a wear mark or worse.
        Ride Safe!
        Ron
          where do u get a replacement...
            Find your nearest Ridenow Powersports dealership and shop new and pre-owned motorcycles, ATVs, personal watercraft, and more from the biggest brands in the industry.
            part numbers:
            22: RUBBER, Front. FUEL TANK 74512-001 $10.84
            23: RUBBER, FUEL TANK SIDE 74847-001 $5.76
            25: RUBBER, Rear. FUEL TANK 77513-001 $15.62
            Prices are EACH from the Bikebandit website
              My tank would rattle under certain conditions with out them, I used short sections of fuel line sliced n half to replace mine
                Honda Suzuki Kawasaki Yamaha OEM motorcycle atv and side by side parts with a full line of aftermarket accessories.
