hay guys
i went last night to finish the vfr rear wheel mod to my spindle.
and found out that the steel is to hard for a typical bit or hhs endmill to cut
and i would need a 12mm solid carbide endmill to do the job my self. well that bit cost $50!
then i thought 47 for 4 lugs and 4 bolts then 50 for the bit i will have almost 100 in this spindle i could buy another one (already modded if im lucky) for about that.
and i do understand there are many ways to get a vfr rim on a hawk, this is the most common and i figured this would be the safest way to do it.
has anyone ever completed this mod (using the vfr lug bolts going into enlarged drive pin bolts) on there own. if you did how did you go about boring the holes out???
and for those that paid how much did the shop charge you for this work???
im will be finished polishing my rim this weekend and wanted to put the rear end together and take some pics need to figure out the cheap way to finish the job.
polished parts so far:
swing arm
cush drive cover
vfr rim
rear brake bracket
ally chain cover
parts i got and still need work:
cbr 1000 forks
frame
cbr900 rear shock hawk spring (may get a rattle can flat black paint job with a chromed spring)
pics to come...
had the crazy thought of chroming a tank with all this polished aluminum but i think that would be to much...
swing arm
cush drive cover
vfr rim
rear brake bracket
ally chain cover
cbr 1000 forks
frame
pics to come...
