My bike has intermittently had this problem since I bought it. It pulls pretty well to 6,000rpm, but then starts making this crackling sound in the engine that almost sounds like detonation, and the power drops off dramatically. I can do a wheelie and once it hits 6,000rpm it sits back down again.
I've fixed this before. After I got sick of it the first time I yanked the tank off and found out it had uni pods on there and stock 138/132 main jets. I cleaned the jets and hogged out the 132 a bit with a screwdriver and the sound seemed to go away and the power came back, albeit temporarily.
I then changed up to 145 jets on both ends with no needle adjustments, and it seemed to work out. It felt so good that I went to the track. I only managed a [email protected], which isn't even close to what it should be trapping, especially considering I weigh about 130lbs, which is well shy of the test riders who've cracked off 100-102mph trap speeds on stock Hawks.
and that drag run was when it WASN'T having the power loss problem up top, so imagine how shitty it is when the problem is present.
So yeah, there's a problem there. Another time I had this problem it wasn't even a fuel thing. The cdi connector had corroded to the point where the bike wasn't charging, and it gave me the exact same symptoms - detonating, major loss of power up top.
I'd added shims under the needles to get some more midrange which was nice, but after a couple weeks the detonation and cracking returned, and it's back with a vengeance. It appears to be getting worse, that is the sound is louder, and the power loss almost like hitting a brick wall.
So, ya know, help?
So, ya know, help?
