What do you guys use to clean the old head gasket material off of the head and cylinder?
What do you use to clean head gasket surface?
I use a 3M attachment... it's made of a rubbery type plastic with impregnated abrasives. It's got all kinds of fingers and fits on a die grinder.
Used to use Roloc wheels, but they can remove too much metal... I'll see if I can find a pic of what I'm talking about
Edit - Alright... I guess they're called Roloc Bristle Discs...
Originally Posted by bill-nsI use a 3M attachment... it's made of a rubbery type plastic with impregnated abrasives. It's got all kinds of fingers and fits on a die grinder.
http://www.autobodytoolmart.com/pc-1...2-3-discs.aspx
Originally Posted by MrDude_1Originally Posted by bill-nsI use a 3M attachment... it's made of a rubbery type plastic with impregnated abrasives. It's got all kinds of fingers and fits on a die grinder.
http://www.autobodytoolmart.com/pc-1...2-3-discs.aspxwhatsoever your hand should find to do, do it gladly, because there is no work, love, knowledge, or wisdom in the grave...
First I carefully use a razer blade to remove most of the gasket.
Then I use these 3M Scotch Brite pads with a block of wood like I am sanding a piece of wood. I also find keeping the surface wet with carb cleaner helps a lot. I use the maroon color. The proper manufacture name is Scotch-Brite General Purpose Hand Pad
I tried to find the 3M green disc but had no luck at Sears, Home Depot, Lowes, and local painting supply stores.
Scotch brite is tough because little bits are constantly coming off, you definately do not want these in your engine. My Snap-on guy sells the roloc discs, Id check there.whatsoever your hand should find to do, do it gladly, because there is no work, love, knowledge, or wisdom in the grave...
Originally Posted by cafebaltimoreFirst I carefully use a razer blade to remove most of the gasket.
http://www.freemansupply.com/ScotchBriteIndustr.htm
NAPA has the 3M attachements in the store... my local advance auto also has them, but i dont think all of the stores keep them in stock.
