Helmet lock
    Helmet lock
    Of all the silly little bits I saved, I somehow threw away the only one I wanted, the stock helmet lock. I was going to modify it and mount it to the subframe, the only real reason was to use the ignition key.
    So I purchased a Motion pro helmet lock, meant to be clamped to a piece of tube, tossed the other half, drilled, tapped, and mounted it under the seat. Not amazing, though useful...
    Looks good, definately mounts better than a chopped up stock one would.
