Swingarm and Rear Hub Grease
    Any recommendations are what I type o grease to use for the rolling bearings in these?
    General purpose wheel bearing grease is fine.
    The red kind is a little better than green.
    The outside of the eccentric where it is clamped by the pinch bolt does not necessarily need grease. I run mine dry with no problems. It only needs to rotate a little when you adjust the chain tension.
      i am using CV grease
        Cool. Thanks fellas.
          i use synthetic high temp wheel bearing grease... same stuff thats used in performance cars.
