HOW TO section request: Basic Hawk Tuneup
    My Hawk hasn't been tuned in over a year, and I would like to learn to do it myself, rather than pay Honda (again) a few hundred bucks for a not-so-great job. Could anybody run down the basic procedure for a tuneup? I've never done it but guessing it involves:
    • New plugs,
    • replace or clean air/fuel filters
    • Change oil
    • Adjust idle speed
    • Adjust carbs (needles/floats)
    • Sync carbs
    if needed
    • Adjust valves
    • Adjust throttle/clutch
    Any tips/links for the adjusting parts (idle, carb sync, throttle/clutch) would be helpful. I know that most of these are addressed in detail elsewhere, but it would be great to see a list of the whole procedure, and the order in which it should be done...
    Thanks All!
    i would add checking
    tires- tread and pressure
    chain and sprokets- for wear and slak
    brakes- fluid levels and pad wear
    if you really want to do a good job change oil in the forks
    and dont for get a new oil filter if your changing the motor oil
    also think about taking the pedcock out and clean the filter on that too.
    good idea
      Chapter 3 in the service manual is all about maintenance. Has a schedule and pointers to how to do the maint.
