Brake Fluid
    Brake Fluid
    I've seen it mentioned on here but for clarification:
    Is the stock fluid DOT 4? I've only used DOT 3 in cars and thats all I have lying around. I don't think I've seen DOT 4 at the autoparts store, is it off to the dreaded Honda dealer?
    I have always used either Dot 4 or Dot 5 in my cars... I got my Dot 4 at a auto parts chain store.
      I don't think dot 4 and 5 mix.
      Dot 3 and 4 mix.
        correct me if im worng but if they dont mix you should rebuild and replace all the seals on the calipers, right?
          I never mixed the 2. I used Dot 5 in my more hopped up cars (GTI, turbo A4, Quattor Coupe) and Dot 4 for regular brake work.
          as for changing out seals...never done it and never had a problem.
            From the Hawk Manual: Use only Dot 4 Brake Fluid.
            88 Bros
            93 Supra TT 6sp
            03 Sh*tbox Opel Combo
              http://www.shotimes.com/SHO3brakefluid.html
                Good link Doc, Thanks
                  DOT3 and DOT4 are both identical hydraulic fluids... the major diff is the required minimal wet and dry boiling points.
                  because of this, they can mix... and most good fluids say " for DOT 3 and/or DOT4 brake systems"
                  DOT5 is silicone based... its not superior in anyway other then it does not attract water. applications for it are show cars that sit around for months and years... some marine craft, ect...
                  it is NOT a higher performing fluid.. look in the best race cars/bikes in the world, they all run some form of racing hydraulic fluid or DOT3/4 style fluid.... they do not run silicone fluid....
                  DOT 5 cannot be mixed with any other brake fluid. DOT5 generally needs the system rebuilt to be clean enough for it
