I just got finished installing the racetechs with my mechanic and something must have gone drastically wrong.
Current setup
Race tech 2 turns in from loose spring
Oil height 165mm (6.5 inches)(race tech in, no spring, no spacers)
****Oil level checked with forks fully extended****
Pre load - spacer comes all the way to the top of the tube when the stanchion is fully extended. The cap then pre-loads the spring.
.90 Racetech springs (i'm 230 pounds)
Oil Weight 15
Drilled two new holes in damper rod (88 model - 4 8.8mm holes already existed) Total now is six 8.8mm holes
Result : So stiff that not even half of the useable suspension range gets used up (As tested by the mechanic who got the back wheel up in the air)
Any ideas what went wrong?
I'm going back to him in about 4 hours to change the oil weight down to 10 as it says in the racetech manual. The mechanic thinks the oil weight is the problem.
Thanks for any help that you can lend.
Current setup
Oil Weight 15
