CLUTCH PROBLEM
    CLUTCH PROBLEM
    Hello,
    I am a newbie to this forum. I have a 1989 NT650 with 11,000 miles. I have owned it for a few years and about 5,000 miles. Just yesterday the clutch started slipping under full throttle above 6,000rpm. Interestingly it only happenned in 3rd gear. I am using Castrol GTX 10W40. Fresh oil change. I have a new set of Barnett plates. Should I just install them? How about the springs?
    Thanks for your help!
    Only in third? and no other gear over 6000? Huh? odd.
    If you have the Barnett you might as well throw it in there, and while your at it get a couple heavy duty springs to put in there as well.. oh and a shift kit.
      And make sure you don't use regular motor oil....I was told that regular motor oil saturates the clutch discs. Maybe it's just a sales pitch to buy "motorcycle" motor oil, but that is what I have been told. Definitely get different springs, it makes a big difference
        i think the reg motor oil issue is the additive "moly" in the oil....causes some issues with slippage...not a prob on dry clutches of course , hence the reason ducati uses moly in the oil they use....
          I use ordinary car 10w40 mineral oil in mine. No issues.
            I read this and believed it, now I run rotella synthetic 5w-40 but you could probably run baby oil in a honda and never break it.
              I would also chime in to give an oil change to something like Shell's Rotella-T. And see what happens.
              However when my clutch started slipping at full throttle from 4th to 5th I knew it was time...... um, but that was at around 42K miles! I'm also the original owner. If the Previous Owner was a limp wristed clutch dragger.... It may have been abused.
              Mark
              88 HawkGT (original owner)
              99 Concours
              02 VFR800
