Hawk GT component weight chart
    Found this on the azmotorsports hawk page. They just keep improving on their love of hawks! More parts also.
    If you could only run like kip, w/o the motor! The bike would be way lighter!!!
    That link does not work you need a user name and password.
      Hmmmm.... works when I click it.... try this link and then go to the weight chart:
        That works but then when you click the weight chart link on the left it asked for a user name and password ...I tried to enter something then then tried to just click the X button and it brings me to a not authorized page.
          Here you go! Don't know why you can't get access.... maybe its an accross the pond thing
          these weights are in pounds... sorry, er... the USA prefers to go its own weigh...
          Honda NT650
          Component Weights
          Parts Description Weight
          (Stock unless noted)
          Engine - No oil or carbs 130.0
          Frame 19.5
          Rear Fender 2.1
          Rear Sub Frame 9.5
          Swingarm - Bare 9.0
          Rear Wheel - No tire 13.0
          Front Wheel - No disk rotor 10.2
          Rear Shock 7.3
          Fox Shock 8.5
          CBR900 '96 Shock 7.0
          Stock Seat 4.0
          Corbin Single Gunfighter Seat 6.8
          Centerstand 3.0
          Turn Signal 0.6
          Speedo/Tach 2.5
          Headlight w/aluminum plates 2.5
          Rear caliper, master cylinder,
          brake lever, footpeg assembly 5.2
          Footpeg 0.5
          Stock Mirror 0.7
          Battery 6.5
          Chainguard 0.6
          Radiator and fan 3.6
          Rear disk rotor 2.4
          Front disc rotor 3.7
          EBC Pro-lite floating alum rotor 3.6
          Sprocket/cush drive w/44t alum 2.3
          Rear axle 4.0
          Rear caliper mount 1.3
          Rear wheel concentric adjuster 2.4
          Rubber swingarm guard 0.3
          Stock headers 4.5
          Rear Fender extension 0.4
          TBR muffler 3.4
          Stock front fender 0.6
          CB-1 front fender 0.9
          Front fender brace 0.6
          Fuel tank 10.0
          Seat cowl 2.5
          Radiator side covers 0.4
          Left footpeg and plate 1.1
          Front engine mount bolt 0.9
          Shift lever, rod and arm 0.6
          DID 520 V O-ring chain 3.7
          Steel crossover exhaust pipe 3.5
          Coolant tank 0.4
          Water hoses (3) 0.8
          Fuel lines 0.4
          Fuel pump and filter 1.3
          Thermostat and spigot 0.8
          Petcock 0.3
          Ignition coil and wires (each) 0.9
          Rectifier 0.8
          Sidestand and mount 2.3
          Rear engine mounts and bolts 2.6
          Wiring harness 5.5
          Clutch, throttle and choke cables 1.5
          Radiator guard 0.4
          Cooling hose guard 0.2
          Horn 0.8
          Headlight wire mount 0.6
          Bar weight 0.7
          Stock bars 2.0
          CBR1000 bars 2.5
          Fork tube 3.3
          Fork lower 1.8
          Progressive spring 2.0
          Fork Internals 0.8
          Fork cap 0.2
          Air box with filter 3.3
          Carburator Assembly 4.0
            Thanks, that really cool
