Brake piston compression?
    I am changing my front and rear brake pads, and am having trouble compressing the pistons of the calipers in order to get the new pads on. Is their a trick of the trade to complete this task?
    Thank you
    Yusef Khan
    Honda Hawk->1st bike
    2000 miles in 1st two weeks of riding with Hawk.
    Hi Yusef. Have you taken the top off of the master cylinder? Make sure the pistons are really clean (an old tootbrush is good) and then they should push back in fairly easily, though you should keep an eye on the master cylinder fluid level as it'll rise, of course, as you push the pistons back in.
    I tend to strip the brake calipers every time I put new pads in, makes for a nicer action. You might have to do this if the pistons are really sticky.
    Al
      Originally Posted by DefTrap
      _________________
      <'91 Bros 650 Mk1>
      Front end: Bros Mk2 front wheel; Stealth wavey disc; NC30 front brake.
      Hi AL , is this right , you use one NC30 caliper ? do you know , that the pistons of the NC30 calipers are smaller as the pistons of the RC31 BROS or RC30 caliper
      @ hawkhan : there are tools to push the pistons
        Yep. Works fine.
        I don't think it's necessary on calipers with reasonable access. Generally I'd say that if you can't push the pistons back in under finger pressure then they deserve a strip down or there's something else amiss. Nice tool though - I like tools.
          Yep. Works fine.
          That´s good
          Here´s my tool for the oem HAWK caliber
            And here's mine -
              How difficult is it rebuild the caliper, recently I had to push mine back with a clamp and even that was hard.
              Is there a rebuild kit available.
                Toad, yes Bros caliper spares available with WEMOTO.
                Pistons, seals...
                  Easy... Just did it on a friends bike the other day. I hope I did it right....
                    Thanks guy I'll get them with my monthly order to wemoto and only £19 just saw the "Speedo and Tacho Cover - Top Case"--have to have that as well -£42-- One day I'll buy so many parts is won't be the same bike................it will be Better..
                      strip the caliper? What does that mean?
                        dirk
                        we must shop at the same tool shop, I use that also.
                          Originally Posted by kiwi
                          dirk
                          and it works
                            Remove caliper from fork leg.
                            Push pistons out under fluid pressure (can go into more detail here if you want to do this).
                            Split brake caliper.
                            Remove pistons seals.
                            Thoroughly clean brake caliper.
                            Refit seals if serviceable or bung new ones in.
                            Refit pistons (discussed above).
                            Refit caliper.
                            Prime and bleed brake system (again, can go into more detail here if you want to do this).
                            It's not that hard, honest.
