how many turns out can I get before it risks falling right out...I am trying to solve a popping on decel problem
mixtire screw questions
Roughly 5 I reckon.'95 ShaftHawk 650P>
As service shop, you ma be able to explain why, but popping on decel, or for me, on startup, is sometimes caused by air getting into the exhaust. Check the exhaust port studs for tightness. Sometimes the P.O. did not put a new copper crush gasket, causing a poor seal or vibration wears the mating parts. -Just a thought.-I'm sorry....I did not know she was your sister.
Well, I am almost sure that it is doing it from the fresh air getting into that open meg and burning up anything left over...
I decided to build a baffle into the mid-pipe and pack it...the setup looks so awesome I can't change muffler...it's a Hotbodies meant for an R6 and I will try to post up pics soon. You guys will love it!
It's jetted for a full system based on Factory's specs. I will definitely have to make adjustments but it is actually a really good starting point.
Thanks for the help...I'll be a regular on this site as soon as I can find the time.
Tom
