A huge favor from you Vapor Owners!
    Ive done a search and read all posts and info. It looks like a great set-up,
    However I would like to see what all the sensors look like monted up .I.E. speedo sensor, water temp sensor ect ect...
    If one or more of you will post some pic I would be very aprecative!
    Thank you!
    I may be able to get a pic tonight...
      I remembered, then I forgot last night... I will try again tonight.
        No problem!
        Thanks for doing this for me!!
          Ok... can't get you a better picture than this, because my front end is currently torn apart. I had to shorten the pinch bolt by about 2 threads or so to leave enough room to use another bolt to hold the sensor in.
          I used the mag. bolt that came with the kit... but I have a 600rr front end, and apparently this bolt doesn't fit the hawk rotor. You may want to use another bolt/method for the magnet.
          With the caliper installed, very little of the cable/sensor is noticable.
          Hope this helps!
          edit... couple more things I remembered... you'll notice one of the corners is cut off the sensor mount for clearance, and I heated up the wire covering a bit to enable an easier bend.
            Thank you!!
