Everywhere i've looked seems to suggest that I measure rear sag between two very subjective points on the rear axle and subframe. Suggestions are then made in mm rather than percentage of full range at those particular points. No consideration seems to be given to the fact that these points are on the end of a lever away from the shock.
To anyone who can spare a minute to explain it. How can to tuners using different measure points still work on the same number of mm of sag.
Where is the best place to measure between on the hawk and what kind of Free/static sag figures do you guys have.
I have seen the very detailed setup instructions in the Faq which suggests going vertically up from the axle but hot can you apply this to two different bikes with two different swingarm lengths.
Any light shed on the subject would be a great help as I've read just about everything there ois about it on the net and there is no further explanation to be found which takes into account the length of the swing arm and the actual shock travel.
