So I've taken off the goofy looking chain guard and now I'm left with the loose rear brake line. I worry a bit about the line rubbing the chain or tire, not that it has yet. Anyone have ideas for an inexpensive way to hold the brake line or make a cheap small guard to attach to the swingarm that can hold the line? (cheap being a key word, the easter bunny bought the kids a swing set) I thought about wiring the line to the plastic fender near the shock but that puts it pretty close to the tire. I've been to the local hardware store and have a few ideas but am looking for anything else. Running the line through the swingarm is out of the question.
Chain guard
yes..take a piece of sheet metal and bend it into a rectangle that your chain can run through it, with 2 holes to mount into the screws that your old chain guard was mounted too.
Bfizzle could probably take pics of his. You then just drill small holes in the top in 2 or 3 places to zip tie your brake line too. It looks pretty good.
I like that too, I think that would be easy enough to make from some metal at the local hardware store. I know what I'm doing this week.-God, grant me the serenity to accept the things I cannot change, the courage to change the things I can, and the wisdom to hide the bodies of the people I had to kill because they annoyed me.
Robb Z from the List used to make laser-cut aluminum jobbies... he stopped making them but he may have a couple laying around. Give him a shout.
Go to "the Goose" in Members Rides... mine's got one.1988 "BlackHawk" project
I've got RobbZ's peice as well: http://community.webshots.com/photo/...5762154aVCjvS#Mark
88 HawkGT (original owner)
99 Concours
02 VFR800
Originally Posted by TuskI've got RobbZ's peice as well: http://community.webshots.com/photo/...5762154aVCjvS#The Democrats are the party that says government will make you smarter, taller, richer, and remove the crabgrass on your lawn. The Republicans are the party that says government doesn't work and then they get elected and prove it.
P. J. O'Rourke
99 Concours
02 VFR800
