F2 Fork Modifications Questions
    I have just purchased a 1988 650 Bros from Japan. I have a F2 front end that I would like to install. Having read through the forum, I do have a couple of questions.
    1) The piston on the F2 has 2 holes, is it recommended to weld up one of the holes on the F2? (Like the Hawks forks).
    2) In keeping the stock F2 spring, should I cut a couple of coils off the bottom of the spring and put a longer spacer in?
    3) And last but not least, if I do, what weight oil should I put in. I assume 15 weight.
    I weigh 190 with gear.
    I am setting this bike up for track days only, and I know that I should be putting Race Tech springs and emulators in but I just ordered a Penske rear shock and slicks so there’s no money left.
    Any help would be greatly appreciated.
    Thanks Terry
    88 Hawk
    94 ZX11
    92 RM 250
    04 CRF 450
    Bolt em on and run em.
      Thanks Doc, it's soo nice to hear that on a mod..."Bolt em on and run em". Too easy.
      88 Hawk
      94 ZX11
      92 RM 250
      04 CRF 450
        Unless they are 94 forks (cartridge), the f2 and hawk forks are identical except for the caliper-mounts on the lowers. All the same tweaks that would apply to stock Hawk forks would apply here.
        89 Red - F2 Front with RT springs, 8983 Penske, Factory 3.0/Pods, Full de-smog, Hord Collector with mini ST can, VFR rear,
        Corbin saddle, Rattle-can make-over, Assorted Nips and Tucks, Gum, Duct Tape.
