if the Honda Deauville is fuel injected....
    does that mean theres a set of OEM throttlebodys and fuel rails that will just bolt into the hawk?
    Now that's a good question...bearing in mind that the Dullville is a totally different beast, tho (read: BORING!).
    Bang your head here for an instant IQ rating
      naa, i dont want the whole EFI system.. i was just thinking.. an aftermarket ECU, a fuel pump/regulator... and this stock throttlebody/injector/fuelrail... and you could have an EFI hawk.
      i wouldnt do it to mine.. the whole point is to make it as simple and light as possible.. but i think it would be a neat project. lol.
        Looks like it should work, but the throttle bodies are only 40mm. Will need to work in the ECU, O2 sensors, other sensors, etc.
        -P.
        I need a bigger garage.
        It's a dirty job but someone's got to do it.
          You may also want to check and see if the electronic fuel injectors require a pulse generator to operate correctly. Ran into that one in the past when trying to convert a CBR 600 F2 engine into FI.
          1988 Hawk
          Shuriken 1000
            so the TB's aren't a big enough bore for the Hawk?
            I would love to run these with a megasquirt system someday! Just imagine.
            "Suck, Squish, Bang, Blow"
            http://www.hpwcycleservice.com
              I'm figuring aftermarket 50-52mm throttlebodies in the OEM 12-hole injectors. Use OEM parts and aftermarket ECU. What are the TB sizes from the VTX1800, also a 52-dg v-twin?
              -P.
