dropps into neutral
    dropps into neutral
    this is the 3 rd time this happens...getting worried.
    While in 2nd gear, as I'm about to accelerate, the bike shifts into N all by itself. At first I thought that I might have done accidentally. The last time, this has caused me to rev the engine unsuspectically while in a curve.
    What could be the cause of that ???
    thanks
    Dogs are worn.
      my what? lol
        Originally Posted by kamihawk
        my what? lol
        heres a good explanation of motorcycle transmissions...
          crapp! any advice on what to do? would this be considered an emergency/dangerous to continue riding?
            Only happening in second? Just kep your foot pressing up (or down if your using GP) That should keep it there.
            Until you can properly check it out.
              my what? lol
              Dogs or selector forks?
                well. first id check to be SURE you're putting it all the way in gear.. you might not be.. if you do it often, you can angle the shift lever down a tad.. that should naturally fix the problem.
                if it really is engaged fully and its popping out... i would have someone rebuild the trans. its not fun (or cheap) but id rather fix it now, then have to deal with it, and then wear out more parts in the process...
