mounting my right mirror
    I broke the right hand mirror mount in the master cylinder, so i'd like to know what my options are as far as mounting a new mirror somewhere on the right. should i just replace the master cylinder, or try to mount it elsewhere? is a master cylinder expensive? i can post pictures, if necessary.
    You could get bar-end mirrors.
      i can't really tell, are these barends:
        Umm... no.
        These are.
        Or, google "Constructors Racing Group."
          Bumping an old thread...
          I've got and F4 setup on my Hawk and need a master with a mirror mount suitable with the dual caliper setup.
          Anyone know of swaps that would work?
          ~ROB
            just use a replacement mirror clamp on the master cylinder. I have the ones from a honda cb1000r on mine and they do the job superbly! Part numbers below:
            left :45517-MFN-D01
            right :45518-MFN-D01
            These replace the clamp that bolts the master cylinder to the handle bar and allow the mirror to be screwed into this.
            I'm sure there will be cheaper aftermarket options out there, but they work for me and a lot cheaper than a new m/c!!!
            '90 Bros mk I - 954 front end, vapor digi dash, k-tech cbr1100xx shock, full TBR system, cbr900rr rearsets with cbr600rr pegs, fabitappi hugger and seat converter and cb600f8 wing mirrors
            '90 CB-1 - PC frame, cbr1100xx rear shock, 600rr footpegs and rear fender removed
            '84 FJ1100 - fzr400rr front calipers
            Bros 400/750 project - PGM Africa Twin motor, mkII front wheel, race subframe and rvf rear wheel conversion (in progress!!)
            '02 RSV1000R Mille
              That's an awesome idea!
              Do you have a preferred distributor (that'll ship to the US)?
              ~ROB
                should be able to order from any honda dealer as you have the part number!
                '02 RSV1000R Mille
                  sometimes... I amaze myself with my stupid.
                  Edit: Actually American Honda is not importing any parts for bikes that were not intended for the US.
                  So I'm going to get some ducati monster clamps that have them built in. I should have known... I HAVE a monster (refer to first line).
                  Slash still gets the award for the idea though.
                  ~ROB
                    lol! just hurry up and get it sorted!!!!!!
                    '02 RSV1000R Mille
                      Another idea:
                      Use the Hawk master. Internals are identical to the F2 which was a dual rotor setup.
                        to clarify...
                        ...and that's the same for my F4 set-up?
                        That'd be sweet to keep it.
                        ~ROB
                          Should work, as F4 is dual rotor, too.
