Aftermarket Ignition Switch Assembly?
    I need a new aftermarket ignition key/switch assembly (including wheel lock if possible) for my 88' Hawk. I can get aftermarket VFR or CBR switches of similar vintage, has anyone had any success using a VFR or CBR assembly on their Hawk? Thanks.
    You might try checking with JD at hordpower (or your local honda stealership even) to see if the switch can still be ordered. I have wondered about this a little bit on my own but I'll probably work around the issue since I am doing a custom front end.
    2002 DL1000 V-Strom - Workhorse. beat it, flog it, it keeps on going...
      You can order a new ignition switch with 2 keys from Wemoto. Total price including shipping is like $75.
      Ducati Hawk Build
      Hawk #2 Build
      Jetting Database
        Wemoto is great, I ordered the switch and got it in three days, and it fit perfectly.
