Any advice on a sticky choke lever/cable....hopefully without taking things apart?
choke
tiger60Tags: None
These are very neglected in my experience and hard to lube in situ as the cable is in three parts. Proper lubing would involve taking the cable out (removing tank etc) and by that point you may as well just bung in a new one. They used to be really expensive (in the UK anyway, about 40 quid) but I believe there are cheaper pattern replacements from the likes of WEMOTO now.
When replacing the choke cable be careful not to lose the springs and choke needle bits ...'95 ShaftHawk 650P>
if the choke pistons inside the carbs (either one) have stuck in place, cable lube won't help much and will need alot of disassembly.Last edited by squirrelman; 09-07-2019, 05:34 PM."It's only getting worse."
I guess the pictures never loaded like I thought they had.941BEC79-4545-47C9-80D0-5FE8FB41BE70.jpegF1C917D6-FAE2-47ED-9C1E-18E84B58E5B4.jpeg
Originally Posted by nozzle View PostI guess the pictures never loaded like I thought they had.941BEC79-4545-47C9-80D0-5FE8FB41BE70.jpegF1C917D6-FAE2-47ED-9C1E-18E84B58E5B4.jpeg
Doesn't anybody put one end of the cable in the crank case and suck on the other end anymore? All these fancy tools....
Originally Posted by nozzle View PostI guess the pictures never loaded like I thought they had.941BEC79-4545-47C9-80D0-5FE8FB41BE70.jpegF1C917D6-FAE2-47ED-9C1E-18E84B58E5B4.jpeg"It's only getting worse."
