All,
I am borrowing a friends tools this weekend and alcohol and the consequences allowing will be in the garage on Sunday.
I just read on Ryans forum that a guy had the standard hub machined and then added a 1/8th spacer between the hub and wheel to centre it.
Is this correct?
I hadn't even considered that Honda would use a different offset on the wheel/SA assembly.
To find out for sure would I measure from wheel 'hub face' to the inner and outer edges of the wheels?
TIA,
Marc
Is this correct?
TIA,
Marc
