Question about TBR exhaust systems
    are the headers normally this close to the coolant hose?
    Yes.
    Yours looks a little closer, though. Loosen the exhaust studs and swing it away as much as possible. Might gain about 1/8-3/16 more room. Ditch the silly hose slinky (not needed) and apply a small patch of self adhesive aluminum tape on the rad hose to help reflect heat.
      Also sometimes you can loosen the 2 bolts securing the waterpump to the engine case and rotate it back a bit, to get a little more clearance.
        my water pump tube was bent a bit to give a little more clearance too....
          thanks for great tips everyone! i'll use them tomorrow to lessen my paranoia...
