I've got an odd problem with the carbs. The mixture screws are adjusted to 2 1/2 turns out from seated. When I turn the gas on and start the bike up gas starts pouring out of the the small holes on the two ports that connect to the airbox. In the link below, in the first picture, it's the hole on the top left side of the air intake.
I'm totally stumped as to why gas keeps leaking out of both of these. I'm thinking it has something to do with the float valves or levels, but when I pulled the carbs, everything seemed to be in order. Any suggestions?
