Shift and brake pedal/lever
    Does anyone know of a good replacement for the stock shift and brake pedal/lever or is the common opinion that you might as well replace the full rearset?
    Thanks,
    Jason
    I was working on a list... here is the link
      this link seems to be broken
      I was asked, "Would you do it all again? Would you take on another project like this that consumes you? Would you build another Hawk?"
      Can anyone guess the answer to this ?
      _____________________________________
      Darell AKA Neurida81
        CyclePirates levers for the F4i 600.Dagus has a set.
          Shift lever = Honda XR100 (cheap).
            Crash, by "Shift Lever" are you describing the shift pedal or the clutch lever?
              Shift lever.
              Not the Clutch pedal.
              (Seriously many of the XR and dirt bike shift pedals fit for GP shift, try it you'll like GP shift)
              An expensive alternative (could help a racer begging for a spare to fix crash damage trackside) is the shift pedal from an Aprilia RSV1000 (Mille).
