I get a kind of whirring sound coming from the motor when its under load. It's not chain or front end noise. Its more noticeable at higher rpms and goes away when the clutch is pulled in/revs drop. It doesn't feel like the clutch is slipping, but it almost sounds like its the clutch plates making noise. I really have no idea how to diagnose noises so if anyone can help me that'd be great.
That description is vague I guess.
Basically if I take off, as soon as the clutch is out and I'm accelerating there's a whirring noise. If you let off of the throttle it dissapates some and will stop if you pull in the clutch. I don't know if its adding to or causing the problem but I have a fair bit of lurch when rollin on/off the throttle, I'm guessing my cush rubbers are far from cushy and I have a fair amount of slack in the chain due to ride height.
