so for a while now I've had some problems with my rear wheel loosening up (even with a cotterpin in!) and today upon inspection i believe the problem may be that the drive pin holes on my wheel are worn or something. I just got replacing the chain and sprockets and everything was honkie dorie, then last night when i was inspecting my bike i noticed there was a little bit of wobble in rear wheel. And sure as shit the nut was turning a bit with the cotter pin in it even!
So I took the wheel off and I looked at the drive pin holes and they look even worse then the last time I put them on (they've looked like this for a while) and the drive pins even look a little warped.
is that what they're supposed to look like? Because that's how they've been since i got the bike. I'm assuming that it's not... what can i do about this? Can those be replaced or am i looking at getting a new rear tire. Any quick fixes you guys can think of? I just dropped $300 on this guy for chain and sprockets and a new tire, I'm a college kid who can't keep spending like this!
Also I noticed when i was looking at a diagram that there's supposed to be a washer between the nut and the collar for the wheel, mine is missing, could this be playing a role in my problems? (anybody got what size that is?)
AND FINALLY, is there supposed to be a bit of play in the axle? it dosn't turn but it moves up and down a bit, but I don't imagine this is much of a problem when it's torqued to the wheel
[/img]
[/img]
