clutch noise when engauged
  • clutch noise when engauged
    A load metalic rattling noise is heard when engauging the clutch, gears engauge allright, no slipage, oil level ok. Anybody got any idea's or do I need to get the socket set out.
    NC25 J 88
    I've never been inside the Hawk's clutch but generally a noise like that is a throwout bearing or something similar.
    The Democrats are the party that says government will make you smarter, taller, richer, and remove the crabgrass on your lawn. The Republicans are the party that says government doesn't work and then they get elected and prove it.
    P. J. O'Rourke
      clarify, please:
      When you pull the clutch and pop it into gear, there's a metallic "clunk" or something?
      ~or~
      When the clutch lever is pulled there's a consistant metallic grinding noise?
      The former means you need to adjust the cable some. The latter means your bearings are screwy...get ready to replace stuff.
      Want a 5.5" rear wheel? Click Here
        Originally Posted by Makenzie71
        clarify, please:
        When the clutch lever is pulled in load rattling noise no noise when in gear and clutch disengauged better check the bearings by the sound of it
          Mine does this too. Even after a tear down and clutch replacement. I believe it's normal and shouldn't be anything to worry about.
          Mark
          88 HawkGT (original owner)
          99 Concours
          02 VFR800
            from what I have been told by other hawk riders, this is completely normal. Both of my Hawks make this noise, and both have close to new clutches in them.
            Not to worry - just go ride!
            '89 NT650 Hawk GT
            '91 CR125
            '99 KX250
            '97 S-10 (AKA Bike Hauler)
              a little noise is perfectly acceptable. This comes from the friction parts being loosened up a bit and it just allows minor imbalances to make themselves noticed...just about every vehicle with a clutch does it. If the noise is loud and obnoxious then it's bad. Should be pretty subtle.
                loud and very noticable. I suspect the clutch lifter plate bearing as this the only bearing shown in the online parts fiche.
                  Yeah, my '88 does the same thing... a quiet but definate "tack-tack-tack-tack" sound. I always half assumed, half hoped it was normal.
                  Bikes: 88 Hawk, 97 VFR, 06 V-Strom 650
                    just went out for a run on it noise was there when cold but after the it was not so i guess it may be one of things
