Clip On and Cable Question
    Well I have another question just kidding I have tons of questions!!!!!
    As I go through the past threads about clip ons and options. I have tried to do research on the cable aspect of switching the handle bars to clip ons. I have pretty much decided that i am going with the pro-flow clip ons. Anyway, As i look on hordpower.com I see different options for cables.
    Can someone please discribe the difference of "push" and "pull" cables, other than they push or pull. Which would be better for me?
    I need to switch the cables out anyway and want to do it the right way, and not re-route the existing cables.
    Thank you for your continued help, one of these days I will be able to offer my guidance to those who need it, until then I will ask questions.
    Gray
    1990 e30 BMW - not stock (well back to stock for now...boost here i come)
    1989 Honda Hawk Gt 650- CBR 1000rr front end, RS125 tail, Hiperform subframe, Penske 8393 shock, VFR rear wheel, WoodCraft rearsets, etc...
    2005 Honda CBR 600rr- bone stock, daily grinder
    life truly is better with ball bearing turbos
    You'll want one of each. One 'pulls' the butterflies open when you twist the throttle, the other one 'pushes' the butterflies open, but more importantly, when the throttle is closed, the 'push' cable physically closes the butterflies. Sure there is a spring that does this, but if it should ever fail, and if you didn't have a 'push' cable, you would have no way to control the engine (other than killing it).
    E
      thanks E for the reply
      Cheers
      P.S. for all the England Hawkers, i will probably be attending LSE, Lodon School of Economics...or London Economics School, this summer
        Cheers
        I'm in Cambridge - feel free to give me a shout.
        Bringing the Hawk? If you're not then you can pick up a Bros for around the 750 quid mark.
          nope not bringing it, was playing on getting something when I am there!
          I will have to give you a shout when i make it over there. I used to live in Bracknel when i was younger!
