Stuck at work???
    Stuck at work???
    Yesterday I got stuck at work, my hawk wouldn't start. I turn the key ON, and I have no electrical, either the batery is dead or it can't connect it self to the system. I just can't figure it out the only thing I can think, is that the bike did not like the heavy rain we had.
    Any of you have experience with the Hawk elect. system?
    Thanks
    Its not gone yet and I already regret selling it.
    Did you engage the steering lock and inadvertently activate the parking light and thus drain the battery? It is easy enough to do this on a sunny day, you won't notice the brake light shinning, unlikely though as you said it was raining.
    It's a good idea to remove the battery cover in advance, for the dead battery scenario.
    Blade.
      did you try getting a jump from someone and maybe roll starting it?
        had a problem like this with my girfriends 400, it turned out to be the main fuse next to the startor solinoid it had gummed up big time. the actual fuse holder comes apart and i soaked the copper bits in vinegar and gave them a good clean up! its been 100% ever since! HTH!
          This weekend I'll check if the bat. is being charged properly, clean up the kill switch and charge the bat. over night.
          When you turn the key past the steering lock position and engage the parking light can you pull the key out of the ignition switch?
          Some how I don't think the bat. is the problem, ever since I pull the bike out of winter storage it was starting fine. It may be a finger problem like you guy's are saying.
          Thanks for your suggestions.
            Checked every things on my hawk and all is fine, so my conclusion is that the newb turned the ignition switch in the park position and left for the day. Sorry for the trouble guy's ops:
              pull the park fuse then!
                OOOOOhhh where is it??? i've push started my bike more than once because of that damn feature!
                The Democrats are the party that says government will make you smarter, taller, richer, and remove the crabgrass on your lawn. The Republicans are the party that says government doesn't work and then they get elected and prove it.
                P. J. O'Rourke
                  in the fuse box at the front of ya bike under the headlamp, its marked park! i think!
                    If you have the manual, its fuse #1 I beleive. Mine will be taken out very soon.
