Micron can on a 400bros.... do i need to modify anything?
    Hi,
    I bought a micron can CCY33 off of ebay and fitted it to my 400bros 88' model... but it made a strange wherring noise when i decelerated and dropped down gears... the bike just didn't feel right...
    does anyone know if i need to make any modifications to the bike to use this can on it?
    added pic for visual reference:
    cheers'
    ben...
    is your centerstand still fitted to your bike?
      yup, the centre stand is still attached....
      cheers'
      ben...
        then remove it or buy a center stand stop bracket, as you stand is now rubbing on your chain! the orignial stop is on the bottom of you original exhaust which you have removed!
          cheers... i did notice that the chain was touching the centre stand when i was taking the exhaust off... i thought it was 'cos i hadn't tightened my chain for a while... whoops...
          so can this exhaust damage the bike at all?
          and how simular are the engines on a 400 & 650 bros?
          as the exhaust came off a 650...
          thanks for advice...
          ben...
            From what I understand the 400 and 647 are exactly the same engines just that the 400 is sleeved and fitted with smaller pistons.
