anyone know this answer?
what year 900rr rearsets work on a hawk gt?
Why dont you get a set from Rod
http://www.hiperform.com/rear_sets.htm"Life may begin at 40, but it doesn't get real interesting until about 150."
- Ohlins Rear Shock
- F2 front wheel
- VFR750 rear wheel
- Hiperform seat&headers
- MSMotorsport Seat Cowl
Goshawk is correct. The early 900RR rearsets are what fits the hawk. Mine are the pretty Metisse type, but I notice that there are some with ball bearing movement, which I assume will allow much smoother action.
Below is a pic
http://whaccessories.com/RearSetsMET.jpg
93-95 900RR pegs will fit the Hawk
93-95 seem to be the "right" years. They have the correct bolt hole spacing (I believe it's 78mm center-to-center) for the Hawk mounting holes. Later model 900rr rearsets went to 60mm ctc and won't work (found this out the hard way).
Even with the 93-95, some slight adapting and creative bolting seems to be required for the brake cylinder/stop light (at least if you're retaining the Hawk ones), etc. I'm curious though: the Hawk cylinder is 1/2" I believe, and the CBR is 5/16". Would the CBR cylinder work OK with the Hawk rear caliper?
