chain length
    chain length
    Hey there. I just finished putting on a new 46 tooth rear sprocket and a new 16 tooth front sprocket. Both are 520, as is my new chain. The question is, I bought a RK RX-Ring chain 520XSO and was wondering with the new tooth size if I would have to add a link (making it 113 tooth from the stock 112). According to the manufactuer if you add teeth, you should add an extra link. Has anyone else come across this?? thanks
    1986 Honda NS400R
    1988 Honda Hawk GT
    Yes, you should add link(s) for more teeth. You are losing 1.25" of chain when using a 46t sprocket, over a 44t. 5/8" per tooth/link. But really you can only add/remove links in pairs (inner, outer). Which works out since your rear sprocket size increased by two teeth.
    If I were you I would add one inner, and, one outer link to the overall length of the chain, but, dont forget to consider the master link. Which gives you 114 links.
