Using an aftermarket speedo
    Any of you running after market speedos? If so, what are you running and do you recommend it? How how hoops did you have to jump through to get it working?
    Not sure about it, but as I understand all you need to do is mount it, connect the wires for the backlight, and then plug the cable into the reciever down on the wheel. Never done it myself, but should be a pretty simple job.
    I know I dreamed you,
    A sin and a lie.
    I have my freedom,
    But I don't have much time.
    Faith has been broken,
    Tears must be cried.
    Let's do some living,
    After we die.
      I'm pretty sure you have to take the rim size into account. I'd ask the www.hawkgt.com email list.
        I used to run a Veypor set of gauges on my FZR. It was the cheapest digital speedo I can find that had a tach. (I used to run a sigma bike computer on the Hawk when the speedo got bashed in by the damn asphault) One word of advice - use more magnets for the pickup. These can be used with ANY motorcycle, 2 or 4 stroke.
        It's scary how slow I am!
        '88 HawkGT - crashed as all hell - Hiperform subframe, VFR rear wheel, F3 front end, Penske shock.
        '05 Ducati S2R - Monstrack mirrors, CRG levers, Evoluzione clutch slave cylinder, ProItalia tail chop, Arrow damper, Nichols flywheel, Suburban Machinery bars
          GSXR gauges on an '88
          My Hawk has '92 GSXR 600 gauges on it. It had them when I got it, so I don't know all of the details involved in adapting them, but I could take pictures. I think they look far better than the Hawk ones, and they have a separate temp gauge.[/img]
