Well, the clutch on my Hawk is getting worse. It used to only slip a little when downshifting agressively from 5th to 4th to pass, now it's giving a little when I get on it in 2nd. Good thing I ride it around town like a grandpa the majority of the time. So, parts...
Stock OEM clutch plates? aftermarket?
replace the springs? or shim them as was mentioned before?
Is there a side cover gasket that needs to be replaced after it's removed? Or it is O-ring'd?
This Hawk is going to stay close to stock motorwise for the forseeable future. Pods,jetted,exhaust.
Also keep in mind I'm on a broke college budget right now, the cheaper the better until June. I just need to keep it running to get to class.
