At a recent track event, the bike started to sputter/gurgle, like it was missing some ignition cycles. Simultaneously, the gauges (tach and temperature - I don't run the stock speedo) were going crazy. It did this for a second or two then recovered. When it happened again a minute later, I pitted in.
The temperature gauge was clearly no longer accurate, as it indicated cold at one point then nearly at the maximum. The bike seemed to start reliably, though, and I couldn't recreate the missing ignition problem in the pit. I went out for the last session and the bike was fine.
Now, at home, I went out for a ride earlier and the problem returned. The bike died, and I couldn't get it to run. The starter turns, and the motor catches, but it doesn't continue to run. It just fires once or twice. As the bike is started, the headlights/turn signals flash and dim.
I'm thinking it's either an alternator or voltage regulator issue.
Any suggestions or comments?
