The bulb in my headlight decided to take a crap yesterday and I was wondering if there was a bright light I could go with. I've tried several times to get in touch with Will (Milktree) for his headlight harness but no luck. Any help would be greatly appreciated.
Replacement Bulb
Raul,
have you seen these links?
http://www.mahonkin.com/~milktree/ha...relay-harness/
http://www.mahonkin.com/~milktree/he...relay-harness/"Life may begin at 40, but it doesn't get real interesting until about 150."
- Ohlins Rear Shock
- F2 front wheel
- VFR750 rear wheel
- Hiperform seat&headers
- MSMotorsport Seat Cowl
Thanks for the link. I don't think I'd have a problem making the harness it's just that I'm in japan and finding electronic places that speak english it hard to find.The final measure of any rider's skill is the inverse ratio of his preferred traveling speed to the number of bad scars on his body.
Hunter S. Thompson
Originally Posted by PaullyBoyI just went with an APC hyperwhite bulb in mine. It works great. Just make sure its the stock wattage or youll burn your harness. I think its a 55/60 watt. Good luck.The final measure of any rider's skill is the inverse ratio of his preferred traveling speed to the number of bad scars on his body.
Hunter S. Thompson
