I have a complete 2001 gsxr750 front end and don't know how to make it fit because the steering stem and bearings don't match any help would be great thanks
gsxr front end
Call these guys and tell them what you are wanting to do, they will take care of you.
http://www.allballsracing.com/Produc...ngBearings.asp
BrandonBrandon
Alex at www.maberacing.com has one on his racebike. Give him a Holler.BIKES: Honda: RC31 Racebike/ NT650 Streetbike, DUCATI: None at the moment.
Originally Posted by bubatruckingI found the answer to my problem i bought a used cbr 600rr lower tiple tree and press the stem out and swap it in and found out that the lower potion of the stem is a exact match. Just wanted to pass the info on.
All Balls Racing doesn't have what you need.. because no other bike has the same ID and OD for a bearing race to make this swap work.
I'm still sorting out the handling on mine.. the geometries and lengths of the GSXR stuff and Honda forks are a bit off.. If I could redo it I'd go with a USD kit from a RC51, 929, 954, 600RR, etc. That said.. my front end is mad trick.CVMA Expert 434
LD Designs :: Pirelli :: Racer's Edge :: Woodcraft :: Chuckwalla Valley Raceway
I'm pretty sure that 929 triples slip right into the Hawk. Then as long as the fork diameters are the same, all you have to do is insert the GSXR forks into the 929 triples.
dp"A Café Racer will ride all night through a fog storm in freeway traffic to put himself into what somebody told him was the ugliest and tightest decreasing-radius turn since Genghis Khan invented the corkscrew." - Hunter S. Thompson
Originally Posted by canyonchaserI'm pretty sure that 929 triples slip right into the Hawk. Then as long as the fork diameters are the same, all you have to do is insert the GSXR forks into the 929 triples.
dpCVMA Expert 434
Originally Posted by a13xOriginally Posted by canyonchaserI'm pretty sure that 929 triples slip right into the Hawk. Then as long as the fork diameters are the same, all you have to do is insert the GSXR forks into the 929 triples.
dp
I have no idea. I do know that RC51 and 929 triples work. Beyond that I have no idea.
however, I have to ask, why do you want to do this? bling or function. If this is for function save time and money and just get your stock forks reworked/revalved.
Inverted forks really do not work all that well on a Hawk, they are too stiff, too heavy and add to much unsprung weight to the wheel for such a light, low-powered bike. The only advantage is you get better brakes. But a good set of brake pads and SS brake lines will give you all the braking you need. If you really want to go crazy you can add an upgraded full-floating rotor.
If its for bling, well then go crazy and good luck.
Originally Posted by canyonchaser View PostI have no idea. I do know that RC51 and 929 triples work. Beyond that I have no idea.
dp
But each to their own on this mod.'99 Ducati 748 with a 996 conversion
