Ok, so i've been reading the previous posts and some of the archives over on HAWK GT but haven't found an answer to my question. You know that keeper at the bottom of the slide that holds the needle in place? (it has a phillips female head on top) Well I was changing my jets today (trying to get my bike dialed in after a top end rebuild) and i noticed that the keeper actually completely covers one of the holes in the bottom of the slide and partially covers the other.
Now my initial reaction is that this is probably ok since it must've been this way stock. I've rotated the retaining piece and it looks like there is no position where both holes don't have the retainer over at least one of them. Then I think...what is the use of drilling these wider (which I have done) if one is covered and the other is partially covered in the first place.
Anyway...she runs much better with a 150 rear and 152.5 front with pod filters and a wide open exhaust. But there were still stumbles when I took it out on shake out cruise #2 today (shake out cruise #1 was yesterday with the same setup but with 144's. she would pull then flatten...pull then flatten).
Basically i'm just using the 150 and 152.5 because that's all i could get on sunday as most shops are closed where i'm at. I'm planning to try out a 162/165 combo but seeing this keeper got me wondering if i'm suppose to do any modifications to it.
Thanks for any input.
Chris
Chris
