If I get them do I need to switch wheel right away or will the stock hawk wheel and brake fit?
CBR600 F2 forks question
Tags: None
If you want to use your wheel/brake set up, it will work until you get a F2 wheel (dual brakes). The only thing that has come up in the past I have heard is an issue with having the correct spacers in, but that is not a big deal to fix.1986 Honda NS400R
1988 Honda Hawk GT
Well the reason for forks only is due to $$ flow. I found some forks cheap and could get them but just didn't know if I could use the stock parts while I compile the rest of the parts.
I am already in the middle of the F2 tank and monster seat conversion. I do need to rebuild the stock forks due to leaking seals but if I can replace them with the F2 ones while I have them off would be extra cool.
Thnaks
RobRob
Maybe some of the experts will chime in but i don't believe the stock wheel /brake will work with f2 forks. I was just out in my garage and compared (i am in the middle of ALL of the same mods as you) the Hawk brake to the f2 and they are smaller. I don't have a tire on my f2 wheel yet so I put the stocker on it to roll around, with the bigger stock rotor on it i think you would have to make brackets to make the f2 caliper work.
motojay
Did anyone ever answer this?
I read it on the list...
I think I have had nearly every 41mm Honda front end set up at one time or another.
Stock
Stock with F2 wheel
Stock with Emulators and Springs
Hawk/CB1 fork legs, F2 wheel, dual 320mm rotors, F3 calipers, Hawk tubes with emulators and springs.
Full F3 set up.
Put the F2/F3 Tubes in the Hawk lowers. This is a great set-up. Gives you the cartridge adjustability while keeping the nice Hawk fender.
Get a S/S line and some good pads and you will have plenty of braking for the street, if you want more get a six pot set-up from Steve.
In my opinion anything more than this just adds weight and complexity to a street Hawk.
Also adds sex appeal, romance, wow factor, modern look, etc. (Which I totally get. I have Brembo 4 pads and 998 rotors on my Ducati Sport Tourer for heavens sake…)
F2 wheel and Hawk forks work.
Hawk wheel and F2 forks should as well.
(just to clarify)
A single F2 rotor is significantly smaller than a Hawk rotor. If you go this route, your braking ability bight even be reduced-I'm sorry....I did not know she was your sister.
