Hawk Clutch Perch / F2 Clutch Perch
    Just installed CRG levers. To get the Clutch lever, where I want it, maxed on the closest setting.
    It works....but I looked at images of the F2 perch and it looks like the pivot point is closer to the grip....maybe by what is added
    for the mirror mount on the Hawk.
    Make sense?
    I'm pretty sure chuck is sitting on a couple f2 perches. If you need mesurementa I can gat them when I'm up.
    I use the motion pro one's cause they are CHEAP, simple, short and crash well.
      Thanks!
      I found one on Ebay for $12; and local
      seller.
        Report back if it is indeed closer?
          Will do. From the images I have seen;
          it will be. Not sure how much.
            Installed the F2 perch today and that did move the lever back closer to the grip....about 1/2".
            I didn't want it that much closer; but now I can back off the adjuster to the middle.
            Bonus....no unused mirror mount.....looks cleaner.
              Nice man!
                Excellent, thanks for the follow-up.
