Are replacement float needle screens available without an entire kit?
    I'm looking for a set of replacement float needle screens (I guess that's what they are called).
    This is the part that I mean ("circled" in red).
    I have found a number of kits like the float and needle set on this page: https://www.partsnmore.com/parts/honda/nt650/?filters[category]=carb&filters[fitting]=custom.
    I found these through K&L: https://www.klsupply.com/carb-fuel/f...for-keihin.asp but it doesn't look like they are available.
    Has anyone ever bought these separately?
    Thanks
    -- Ryan Chapin
    BikerBunnies! Motorcycle Safety and Peep Carnage: http://bikerbunnies.com
    I've only purchased the kits. Personally I've
    never seen a filter screen only option. K&L aftermarket is what I've usually purchased.
    http://hawkworks.net/hawkfiche/carbu...omponents.html
      Yeah, that link to the K&L page without any option to buy only the screen is all that I saw. I guess the worst case is $20 for two sets from Parts-N-More.
      (shrug)
      -- Ryan Chapin
        i've looked but never found the filters available individually.
          I submitted a contact-us question to the K&L guys to see if they actually sell the filters.
          I'll let you guys know what they say.
          -- Ryan Chapin
            The Parts-N-More guys got back to me; no dice. They only sell them with the kit.
            -- Ryan Chapin
              whats wrong with the screen/filter?
              Gino
              Chain Roller
              2012 CCS LRRS ULSB Champion
              2012 CCS LRRS P89 Champion
              ECK RACING
                Good question.......maybe shop-air damage.....maybe dropped into a carb tank?
                  when my filters did not fit snugly. i grabbed a new razor blade and put 2 of the slightest cuts at about a 30 Degree angle NOT FULLY thru Maybe 1mm into the inside of the plastic. DO NOT REMOVE THESE WINGS. the wings just put enough pressure to old onto the 10MM housing.
                  OH and BTW..... do not cut your fingers when doing this!!!!!!!!
                  Gino
                  Chain Roller
                  ECK RACING
                    They don't stay on the the housing anymore.
                    -- Ryan Chapin
                      Do what I describe above
                      Gino
                      Chain Roller
                      ECK RACING
