Front sprocket help
    Front sprocket help
    After many days of cleaning globs of grease around the front sprocket area, I find a sprocket that slides in and out freely which looks nothing like the manual. I think the heavy grease was keeping it from sliding around.
    see uploaded pictures.
    I tried searching the forum and nothing looks like mine.
    Any advice on how to make this better? Also has 520 chain.
    THANKS!
    You need to ditch that sprocket, retainer and washer.
    Then you need to get the proper "Fixing Plate" PN 23811-MN8-000 and the 2 M6 X 12 bolts (90118-958-003) along with whatever front sprocket (made specifically for a Hawk GT), you want.
      DO WHAT BOB says!
      and BTW do us all a favor and DO NOT WELD IT !!!!!!!
      Gino
      Chain Roller
      2012 CCS LRRS ULSB Champion
      2012 CCS LRRS P89 Champion
      ECK RACING
        Thanks for the part numbers!
          it will be interesting to see what the countershaft looks like once you pull that off.
            is that the EX sprocket setup?
            Gino
            Chain Roller
            ECK RACING
              Probably.EX500 fits with a spacer.
                Sorry for my dumb question but how does the Fixing Plate stay on the shaft without a retainer clip?
                Thanks for all your help to educate me on this!
                  There is a slot on the shaft. The retainer is turned so the teeth don't line up when you put the bolts in.
                  1997 VFR
                    Ah, I see. thanks!
                      Thatís how it works if the teeth on the shaft arenít chewed up from a non-OEM sprocket.
