so yesterday when i was washing my hawk I realized that my rear wheel wobbles around a bit when i grip it on either side and play with it. Is the rear wheel supposed to have some freeplay in it? it hasn't done anything wierd on me, but it dosn't seem right
rear wheel freeplay
Mine also ahas a bit of freeplay, but only like 1/64 to 1/32 of an inch. Not really noticable to the eye, only noticable when I grab the wheel and try to wobble it. Is it a sign of bearings going bad? or is it normal?-NEVER LET YOUR FEARS STAND IN THE WAY OF YOUR DREAMS-
When two parts go together, there always has to be a small amount of clearance. Unless it is a press fit. That said, I dont think it should be noticeable, especially at the rear wheel. With the rear wheel in the air, try to determine if the play is in the swingarm, (bushings in the swingarm - not likely the cause) or in the spindle bearings. (more likely)-I'm sorry....I did not know she was your sister.
I thought the Nut was staked to the hub?"Life may begin at 40, but it doesn't get real interesting until about 150."
- Ohlins Rear Shock
- F2 front wheel
- VFR750 rear wheel
- Hiperform seat&headers
- MSMotorsport Seat Cowl
Mine was loose by hand too. I unstaked it and changed the cush drives, regreased everything and put it all back together, tightened the nut and restaked it. No more wiggle-NEVER LET YOUR FEARS STAND IN THE WAY OF YOUR DREAMS-
