Torque value for coolant drain bolt?
    One other person asked this years ago with no answer. It's aggravating it's not in the manual. 10mm flange is 29 ft/lb but that seems WAY WAY WAY too much. Is there a sealing washer here? Something like 7lb/ft sounds about right?
    Agree, 29 lb/ft sounds way too much - 7 lb/ft (10 Nm) sounds a lot better. But that bolt I have only ever handtightened, so don't know specific torque value...
      I would not even attempt to measure the torque applied to that bolt unless the wrench maxed out at 120 inch•lbs.
      There is a goldwing/general honda manual floating around that has a torque table based on diameter, thread pitch, material of the fastener and material it's threading into.
      Better to have it loose and weep than tight and leak.
        Just checked the NT700V manual and it states in general 7 lb/ft (10 Nm) for 6mm bolts and specifically 9 lb/ft (13 Nm) for the water pump cover bolts (including drain bolt with sealing washer):
          #7) 6 x 25 = 7.2 ft lb was my 1st deduction.
          But a flanged 6mm is ( 9 ft lb )
          http://hawkworks.net/hawkfiche/water_pump.html
          1988-91 Honda Hawk GT partsfiche
          Back to the parts fiche water pump
          1 COVER COMP., L. RR. 11350-KW0-000 $53.65
          2 WATER PUMP COMP. 19200-MN8-020 $143.86
          3 COVER, WATER PUMP 19221-MN8-000 $51.12
          4 GASKET 19226-MM9-000 $2.54
          5 CLAMP 32972-MM9-000 $3.69
          6 BOLT, SPECIAL (6X45) 90022-MN8-000 $2.40
          7 BOLT, FLANGE (6X25) 95801-06025-00 $0.62
          8 WASHER (11MM) 90425-300-000 $1.28
          9 OIL SEAL (12X28X7) 91201-MF2-003 $2.80
          10 O-RING (32.95X2.62) 91302-MB0-013 $1.51
          11 PIN, DOWEL (8X14) 94301-08140 $0.85
          12 BOLT, FLANGE (6X22) 96001-06022-00 $0.82
          http://hawkworks.net/manual/1.html#1-5-torque-values
          Standard torque values
          5 mm bolt, nut 5 ( 0.50, 3.6)
          6mm bolt, nut 10 (1.0, 7.2)
          8mm bolt, nut 22 (2.2, 16)
          10mm bolt, nut 35 (3,5, 25)
          12mm bolt, nut 55 (5.5, 40)
          5mm screw 4 (0.40, 2.9)
          6mm screw, 6mm bolt with 8mm head 9 (0.9, 6.5)
          6mm flange bolt, nut 12 (1.2, 9)
          8mm flange bolt, nut 27 (2.7, 20)
          10mm flange bolt, nut 40 (4.0, 29)
          Engine
          Spark plug 12 14 (1.4, 10)
          Cylinder head cover bolt 6 10 (1.0, 7.2) Special bolt
          Camshaft holder bolt 8 23 (2.3, 17)
          8mm nut 8 23 (2.3, 17)
          6mm bolt 6 10 (1.0, 7.2)
          Cylinder head nut 10 48 (4.8, 35)
          bolt 8 23 (2.3, 17)
          6mm bolt 6 10 (1.0, 7.2) socket bolt
          Camshaft sprocket bolt 7 23 (2.3, 17) NOTE 1
          Clutch lock nut 18 130 (13.0, 94) Staked nut.
          right crancase cover bolt 6 10 (1.0, 7.2)
          left crancase cover bolt 6 10 (1.0, 7.2)
          Oil filter cartridge 20 10 (1.0, 7.2) Apply clean engine oil to the O-ring
          Oil drain bolt 14 35 (3.5, 25)
          Neutral Switch 10 12 (1.2, 9)
          Oil pressue switch - 12 (1.2, 9) NOTE 4
          Primary drive gear bolt 12 90 (9.0, 65) UBS bolt, NOTE 2
          Flywheel bolt 12 130 (13.0, 94) Left hand threads, NOTE 2
          Starter one way clutch 8 30 (3.0, 22) Torx bolt, NOTE 1
          Oil controll bolt 10 23 (2.3, 17)
          Oil pipe bolt 7 10 (1.0, 7.2) Special Bolt
          Connecting rod cap nut 8 34 (3.4, 25)
          Crankcase bolt 8 27 (2.7, 20) NOTE 2
          6 12 (1.2, 9) NOTE 2
          Shift drum stopper plate bolt 6 26 (2.6, 19) NOTE 1
          Insulator band screw 5 4 (0.4, 2.9) NOTE 2
          Timing hole cap 14 10 (1.0, 7.2) NOTE 3
          Crankshaft hole cap 30 15 (1.5, 11) NOTE 3
          Oil pump driven sprocket bolt 6 15 (1.5, 11) NOTE 1
          Valve adjusting screw lock nut 7 23 (2.3, 17)
          Cylinder stud bolt 8mm 8 20-30 (2.0-3.0, 14-22) NOTE 1, Refer section 10.
          10mm 10 30-50 (3.0-5.0, 22-36) NOTE 1, Refer section 10.
          Page 1-6
          Frame
          Front engine bracket bolt 8 28 (2.8, 20)
          Front engine mounting bolt 10 40 (4.0, 29)
          Rear upper engine mounting bolt 10 40 (4.0, 29) NOTE 2
          --mounting bolt lock nut 22 55 (5.5, 40)
          --mounting bolt adjusting bolt 22 11 (1.1,
          Gearshift arm bolt 6 12 (1.2, 9)
          Thermostatic switch 16 18 (1.8, 13) NOTE 4
          Exhaust pipe joint nut 8 27 (2.7, 20)
          Muffler band bolt 8 27 (2.7, 20)
          Muffler mounting bolt 8 27 (2.7, 20)
          Fuel tank mounting bolt -- front 6 12 (1.2, 9)
          Fuel tank mounting bolt -- rear 8 22 (2.2, 16)
          Fuel filter bracket bolt 6 22 (2.2, 16)
          Front brake master cylinder holder 6 12 (1.2, 9)
          Brake oil bolt 10 30 (3.0, 22)
          Brake resevoir screw 4 1.5 (0.2, 1.4)
          Bleed valve 7 6 (0.6, 4.3)
          Front caliper mounting bolt 8 27 (2.7, 20) Flange bolt
          Front caliper pin bolt 10 28 (2.8, 20)
          Pad pin 10 17 (1.7, 12)
          Pad pin plug 10 2.5 (0.25, 1.8
          Front brake disk retaining bolt 8 40 (4.0, 29) NOTE 1
          Rear brake resevoir mounting screw 6 9 (0.9, 6.5)
          Rear brake disk retaining bolt 8 35 (3.5, 25)
          --retaining bolt lock nut 8 9 (0.9, 7)
          Rear caliper mounting bolt 8 27 (2.7, 20)
          Rear caliper pivot bolt 8 22 (2.2, 16)
          Brake torque rod bolt 10 35 (3.5, 25)
          Handlebar pinch bolt 8 27 (2.7, 20)
          Ignition switch mounting bolt 8 25 (2.5, 1
          Fork pinch bolt (upper) 7 11 (1.1,
          Fork pinch bolt (lower) 10 50 (5.0, 36) NOTE 2
          Fork tube cap - 23 (2.3, 17)
          Fork socket bolt 8 17 (1.7, 12) NOTE 1
          Steering bearing adjustment nut 26 20 (2.0, 14) NOTE 2
          Steering stem nut 24 105 (10.5, 76) Flange nut
          Front axle bolt 14 60 (6.0, 43)
          Front axle pinch bolt 8 22 (2.2, 16)
          Rear Wheel nut 18 120 (12.0, 87)
          Eccentric bearing carrier lock nut 35 165 (16.5, 120) Staked nut
          Shock absorber upper mounting bolt 12 65 (6.5, 47) Flange bolt
          Shock absorber lower mounting bolt 10 45 (4.5, 33) Cap nut
          Shock absorber damper rod lock nut 14 62 (6.2, 45) NOTE 1
          Swingarm adjusting bolt 26 15 (1.5, 11)
          Swingarm adjusting bolt lock nut 26 65 (6.5, 47)
          Swingarm pivot nut 14 65 (6.5, 47)
          eccentric bearing carrier pinch bolt 16 75 (7.5, 54)
          Sprocket mounting bolt 8 43 (4.3, 31)
          Foot peg bracket bolt 8 27 (2.7, 20)
          Sub-frame mounting bolt 10 40 (4.0, 29)
          Side stand pivot bolt 10 38 (3.8, 27)
          Side stand bracket bolt 8 28 (2.8, 20)
          Center stand mounting bolt 10 55 (5.5, 40) Using a box wrench.
          Ignition switch mounting bolt 6 25 (2.5, 1 Torx bolt.
